Xerox 5665: deletions, white areas on pictures (again)
  • ondemandprint
    • Sep 2016
    • 87
    Sorry for my previous thread, it was corrupted by my mistake due word " print " at the end of the title.
    White areas on print. Both simplex and duplex.
    Counter is an 1 100 000.
    1) Drum have been changed (but used corotron is the same). No differences at all.
    2) Developer assembly have been changed (on other used). No differences at all.
    Direction of print: A4 LEF.
  • Exok
    • Jun 2011
    • 750
    Re: Xerox 5665: deletions, white areas on pictures (again)
    This can happen if the paper buckles too much at registration. The paper is not laying flat as it passes under the drum. First, ensure that it happens from all paper trays & bypass. If it does, start by doing the registration adjustments. Next play around with the registration buckle adjustment.
    • adriansto
      • 2388
      Panic stop of machine and check image on drum.
      It is easy with A3 and SEF of course.
      • SeniorTch
        • Jun 2017
        • 117
        check if the short path assembly is going up correctly. Sometimes it does not rise evenly and produces this defect.
        • Richard.Xerox
          • Jun 2015
          • 73
          THIS.
          Especially inboard end of short paper path (towards rear of machine) sometimes doesn't lift up fully when the front is latched.
          • Eagle
            • Mar 2010
            • 49
            You have a Transfer problem. Image not transferring on to paper
            # Open fresh ream of paper and try.
            # check, replaced transfer roll or assy
            P.s if there is a problem with the registration assy the paper would Not be flat. Meaning there would be high and low points, in dense or creasing in the white area were you have the deleted text as show in the sample you provided.
            • eunuch39
              • Aug 2014
              • 40
              [ATTACH=CONFIG]41250[/ATTACH][ATTACH=CONFIG]41251[/ATTACH]
              replace the SHORT paper path
              • ondemandprint
                • Sep 2016
                • 87
                Thank you for responses!
                Just reinstalled the same SHORT PATH module with total connectors cleaning. It's OK now.
