VersaLink C505 MFP Pour Fusing
  • TechGeek
    • 158
    Our company sold a Xerox Veralink C505 MFP to a client that want to print on heavy paper through the tray not the bypass but i am unable to select the heaviest paper weight through the tray only the bypass. I have the tray set to lightweight card stock and 90% of the time this works just fine but every now and again the toner will flake of when printing the second side. I have scoured the manual but i can not find how i cant find any way to increase the fusing temperature just a little bit. Does anyone have any idea on how i can increase the fusing temp 5 to 10 degrees more?
    Re: VersaLink C505 MFP Pour Fusing
    compare the weight of the paper to the handling specs for the cassette.. more than likely it is not made to that tray.
    make sure the paper type/weight jive on the copier and the computer print drivers...
    why do they refuse to use the bypass? is it due to tray capacity? if so SOL
    • Richard.Xerox
      • Jun 2015
      • 73
      Machine only supports 60-220 g/m2 but it does support that from both the main tray and the bypass tray.
      See table below from the service manual:
      Doesn't appear to be any control over fuser temperature unless it's hidden in an NVM value, the RAP for unfused image doesn't really lead anywhere.
