Xerox 5775 NVM
+ More Options
Posts
  • Abidqayyum2001
    • May 2017
    • 5
    Xerox 5775 NVM
    Hi!
    Is there any method to reset NVM that stucks on altboot, without replacing it?
    Xerox 5775
    Re: Xerox 5775 NVM
    Originally posted by Abidqayyum2001
    Hi!
    Xerox 5775
    what do you mean " stucks on altboot "?
    depending on the ACCESSORIES on the machine... speed of CPU and other factors
    altboot can take quite a while ( 6550 to me 45 mins )
    are you going by the manual?
    have you tried with the PWS?
    • Richard.Xerox
      • Jun 2015
      • 73
      Re: Xerox 5775 NVM
      If an altboot fails try a lower version of firmware. Sometimes on this family the same firmware version wont go back on. can always upgrade through CWIS after.
      Also a failed HDD will prevent altboot so if the above fails try replacing the HDD.
