Xerox workcentre 7225 slow UI found a resister on the mainboard any know what it is?
  • lmartinez323
    • Feb 2019
    • 5
    [Electrical] Xerox workcentre 7225 slow UI found a resister on the mainboard any know what it is?
    hello techs im having issue with xerox workcentre 7225 i have replaced the HDD before it was a dead machine i change d ram updated d newest firmware but its so slow when selecting copy and scanning slow sometimes i get the error to turn off and on message i fount a resitir on the main board idk what it is? the jump is on j315 to u60 sodered
    Re: Xerox workcentre 7225 slow UI found a resister on the mainboard any know what it
    is the resistor BLOWN?
    do you know what resistors do?
    what makes you think the is slowing down the machine?
    "i change d ram " did you mean you changed memory DIMM? did you use the same type.speed?
    you say "newest firmware" WHICH version?
      check your PM's regarding your other post
      • lmartinez323
        • Feb 2019
        • 5
        how do i edit my post so confussing
          look at YOUR post... below the message area is the word EDIT
          are you really in LA?
          • chemicalx50
            • Apr 2014
            • 39
            Hey guys currently experiencing this same issue very slow ui selecting options takes 4-6 seconds
            • chubblies
              • Jun 2011
              • 155
              That's pretty normal speed for Xerox. They are dog shit slow
              • jhalfhide
                • Apr 2015
                • 454
                This isn't normal. Once fully booted, they're fine. Having had this before, a forced ALTBOOT has always cured it
                Sent from my LYA-L09 using Tapatalk
