Xerox WorkCentre 245 upload firmware
  • Enzo
    • Jul 2009
    • 407
    Hi friends. I have a problem with updating a xerox WorkCentre 245. I have performed System software upgrade from 12.27.24.000 to 12.60.22.000.
    As soon as the update is finished, this screen appears and I can not view the keyboard. How can I solve? Thank you
  • xcopytech
    • Aug 2006
    • 1792
    Re: Xerox WorkCentre 245 upload firmware
    For upgrade dc255 to 12.60.22.xxx software requires that machine have installed 12.60.17.000 software.
    • Enzo
      • Jul 2009
      • 407
      And if I installed 14.50.03.000 version?
      • xcopytech
        • Aug 2006
        • 1792
        14.xxx is for workcentre pro + ps
        13.xxx is for workcentre pro
        12.xxx is for workcentre
        • Enzo
          • Jul 2009
          • 407
          OK, perfect! Why in these machines there is no possibility to print in a4 sef? I have 2 other machines but of the 5645 series and there it works the print in a4 lef.
          • xcopytech
            • Aug 2006
            • 1792
            As I know wc245 have no any issue with printing on A4SEF.
            • Enzo
              • Jul 2009
              • 407
              it does not work with a4 LEF! it shows: "load support". regarding the software update, I put the
              14.60.22.000 version and everything works
              • lgnis
                • Sep 2019
                • 6
                Ready to explore work.
                Respond to the options shown in the window below." and i can not view the options...
                There is a solution?
                Thnx
                • Enzo
                  • Jul 2009
                  • 407
                  I solved by changing version
                  • lgnis
                    • Sep 2019
                    • 6
                    Thnx
                    Reply my self:
                    • Enzo
                      • Jul 2009
                      • 407
                      Hello friends. I have a problem with the xerox 245. I was given this machine as a gift but the controller does not work. i reloaded the software via altboot and now everything is ok. the machine has released the summary sheet, the one that comes out when the reload procedure is successful. but there is a problem. when I send prints, the file name appears in the waiting queue but the print does not come out. the message "held due to resources" appears, as when there is no paper in the drawer. and after a few seconds it is deleted from the list. what can it be? i think i have loaded the right software. I trusted the code on the hard drive, which would be this: 12.27.024. could the wrong software be loaded? how do i figure out which software is suitable for that machine? thank you very much
