Xerox Phaser 7800 SD Card Defective
  • 8ternity
    • Jun 2018
    • 13
    [Misc] Xerox Phaser 7800 SD Card Defective
    Hi,
    We have one printer, a Xerox Phaser 7800 which has defective SD CARD.
    We have a replacement card which is new and empty.
    How can we reprogram the SD CARD.
    We tried an Alt Boot, which is doesn't work.
    I need help on this case please. I have 2 other printer which has the same issue.
    Any help is appreciated.
    NOTE: If anyone has a procedure how to re-create the SD CARD, it will be appreciated. I think its NV_RAM settings need to be installed on the sd-card.
    THanks
  • JrTech
    • Jun 2013
    • 217
    Re: Xerox Phaser 7800 SD Card Defective
    Unfortunately the one you have does not have the boot file on there. That boot file ext is not available as far as I can see on the net. I have tried to crack one of these and there is a shell of a file to see that the SD card is present on the SBC board. No info in the file and I dont remember what the file ext was either. I had to break down and bought one for about $50 from Xerox. If you cant order from Xerox there are a few companies that do specialize in Xerox and only Xerox. The 2 that I can recommend is Parts Drop in NJ or Item Inc in Woodbridge VA has them.
    Hope that helps
    • 8ternity
      • Jun 2018
      • 13
      Hope that helps
      Hi Thanks for the info.
      We have found a Altenate part number on Xerox. They have in stock right now so we will order them with GSN.
      • Richard.Xerox
        • Jun 2015
        • 73
        I'll have images soon of most Xerox SD cards and a way to put those images onto blank SD cards.
        Stay tuned
        • xeroxsharp
          • Nov 2008
          • 270
          OR You need to order xerox SD card for PH 7800 and perform an altboot procedure. Blank sd card from the store is not ok.
          • anonimolettore
            • Mar 2022
            • 1
            Stay tuned
            If you can help me I need Phaser 7800 SD card image... please let me know
            • Alexandr
              • Mar 2022
              • 12
              Originally posted by 8ternity
              Hi,
              THanks
              I can help you solve your problem. I have everything you need to recover
              • 8ternity
                • Jun 2018
                • 13
                I know but the price is more expensive than having a ROM and just reflash a generic SD Card with the Xerox Flash tool.
                • xcopytech
                  • Aug 2006
                  • 1794
                  If still need help contact me at xcopytech@gmail.com
                  • jaytyla
                    • Aug 2022
                    • 1
                    Did you have any luck finding SD card image for Xerox Phaser 7800? I believe the SD card on my machine is having issues as well.
                    • nazimus
                      • Feb 2023
                      • 3
                      bon jour Mr : pouver vous m'aider avec une images de cart sd xerox 7800,
                      merci
                      • adriansto
                        • 2388
                        merci
                        pas gratuitement stoadis@gmail.com
                        • nazimus
                          • Feb 2023
                          • 3
                          pa les moyens financier
                          • adriansto
                            • 2388
                            OK
                            • 8ternity
                              • Jun 2018
                              • 13
