xerox 4265 hdd
  • marli
    • Feb 2019
    • 12
    xerox 4265 hdd
    does anyone have part # for xerox 4265 and know how I can buy the hdd
  • Richard.Xerox
    • Jun 2015
    • 73
    Re: xerox 4265 hdd
    p/n: 007N01703
    Standard 250GB HDD will work but will need formatting by the device as described below:
    Perform the following:
    1. To save the machine settings and templates, ask the customer to export the fax address book, local and group email address books, then perform a cloning procedure from the web UI.
    2. Enter diagnostics, GP 1.
    3. Navigate to the Format Hard Disk menu:
      • 4250/4260: Select Other Routines > Format Hard Disk.
      • 4265: Select Copier Diagnostics > Format Hard Drive.
    4. The hard disk will be re-formatted and the email address books and templates will be deleted.
    5. Ask the customer to import the fax address book, local and group email address books, then install the clone file from the web UI.
