xerox 700 - error code 010-319
  • Darek
    • Mar 2019
    • 2
    I have a xerox 700 it gives me error code 010-319. When I clear it with 744-361 the machine works for a while, then the code comes back.
    Changed fuser, cleaned sensors, tried to deal with it for over 2 months. Everyday I have to clear the error. Please help.
    Re: xerox 700 - error code 010-319
    did you google it or look it up in the SM? efforts you have made aren't close to the fix.
    you have an NVR problem.
    • InterfaceP
      • Jun 2013
      • 488
      I agree you probably have an NVM problem. Try initializing the IOT from Maint/Diag. If that doesn't work, replace the MCU. $$
      Good Luck!
