Xerox DC 242 white lines on prints
  • chrisio
    • Jul 2012
    • 104
    Hi Everyone.
    I have a problem with white lines / deletions occurring across all colours. If I print out pure cmyk you can see the white lines in every page in exactly the same position.
    To me this rules out devs/drums and contamination ros (unless I am extremely unlucky)
    I have attached an image showing the problem and if you look closely at the transition between the edge of the solid color and the lighter colour you can see it smears at points.
    Does anybody have any suggestions as to where to look next?
    Chris
  • Tecnico_Xerox
    • Jan 2019
    • 51
    Re: Xerox DC 242 white lines on prints
    Hello Chrisio
    check that the air duct that is below the U.R. black is not scratching the IBT,
    sometimes this pipeline is uneven and generates this problem.
    Another test you can do is to see if the printed image in the ibt presents the flaw or not
    and thus rule out other xerographic components
    • chrisio
      • Jul 2012
      • 104
      Originally posted by Tecnico_Xerox
      Hello Chrisio
      Thanks - This all started from me swapping the yellow drum/dev out before which it was perfect (other than a worn drum) I removed and reinserted the drums, checked the transfer belt and I cant see anything on there that lines up with the defect im seeing.
      I have checked the dust shield under the black dev and its not catching the transfer belt - I cant seem to stop the machine mid flow to catch an image on the belt but the chevrons seem to be all present and correct but then they don't seem to line up with the defects either.
      It is clearly related to me swapping out the drum and dev powder but im just not sure what.
      Chris
      • Tecnico_Xerox
        • Jan 2019
        • 51
        Hi Chrisio
        taking the picture as a reference there is something that is scratching the image in the IBT,
        possibly the yellow UR that you got this bad putting, you could also check the IBT cleaner and not have something stuck in it.
        To see the image in the IBT use the following procedure:
        - pull out and disconnect the multi-purpose tray (5)
        - remove the Left Upper Cover
        - connect the multiproposito tray again
        - print the cmyk impression test
        - when the image is printed on the IBT turn off the machine immediately
        - Disarm the machine and carefully remove the IBT assembly and check where the problem is being generated.
        I hope this information helps you.
        Greetings.
        • chrisio
          • Jul 2012
          • 104
          thanks. The tech has been out and been through everything - stopped the machine mid print and the image on the transfer belt had the deletions evident. Cleaned up everything possible he could see - laser glasses all clean etc - its almost as if something is hanging down and stroking the image on the transfer belt. Nothing worked. Out of desperation we are changing the transfer belt although both of us are not 100% that is the correct course of action.
          • SeniorTch
            • Jun 2017
            • 116
