Xerox 700 DCP fault 061-327
  • greg thomsen
    • Dec 2018
    • 5
    [Error Code] Xerox 700 DCP fault 061-327
    What can I do about this? tried restarting several times. does it have anything to do with those flat cables in the back?
  • adriansto
    • 2387
    Re: Xerox 700 DCP fault 061-327
    Try to reseat the flat cables from mcu to ros.
    The code reffer to the magenta ros
    • Shurlk
      • Apr 2014
      • 14
      You can try to reseat flat cables on mcu pwb. Look on the contact of flat cables, it maybe damaged. I had such kind of fault. Sometimes it was an error code, sometimes Xerox started and get to the ready state but with no color. Changed flat cable, and error gone.
      • SeniorTch
        • Jun 2017
        • 117
        If you have not serviced the ROS and flat cables before the fault, could be an scracth on the surface of any drum.
