Two issues regarding drums:
I recently replaced the magenta drum on our Xerox 1000 with a new one as the old one had some blind spots and scratches on it. Ever since I get error 42-328 (Drum Motor 4 Phase AB fail). The machine would start up and after a few seconds or a bit later come up with this error. I checked the housing and replaced the bearing of the front housing, it seemed a bit "gritty" and then realised that it seems the drum is quite "tight". If the machine stands and i turn the various drums a bit, all turn quite easy except the magenta one. Swapped it with the yellow and the problem fillowed the drum (error 42-328).
Would I be right to assume then that the drum might be faulty? I got another new drum and the same applies. Or could it be that the drum drive of the various colours maybe has reached end of life?
I am sure the Xerox office here will not replace the drum.
The second issue is that also recently I replaced the cyan drum (also due to scratches) and within about 200 prints i noticed a speck on the print in cyan, upon inspection realised the drum had a "blind spot" or a round nick on it which was caused somewhere within 2000 prints - how is this possible, so soon. What can be done to prolong the life of the drums. Has anyone any success with additional drum coatings? I saw an ad on Youtube where they coat a drum with a varnish which extended its life - dicy business i guess.
Regards
Regards
