Xerox counter reset
  • shashazindah
    • Mar 2019
    • 5
    Xerox counter reset
    Hi 👋. Anyone to know how to reset counter for xerox c3370 machine?
    Re: Xerox counter reset
    what counter are you trying to reset?
    • shashazindah
      • Mar 2019
      • 5
      The main counter. For the meter reading.
        Why are you trying to sell a used machine?
        • mntech
          • Aug 2010
          • 250
          Copiers are like cars, the odometers are there for a reason. I'm not sure if there are any laws against tampering with xerox meters, but i guarantee it is frowned upon in this community!
            Xerox DOES frown on it...
            and here in the USA it can bring you legal problems... not so much in remote countries.. but I as a certified Xerox Service Engineer..
            I would NEVER condone nor give info out to accomplish such a task...
            dirty pool all the way around
            • shashazindah
              • Mar 2019
              • 5
              • Richard.Xerox
                • Jun 2015
                • 73
                So write down the current meter reading before you send it out again, then calculate the difference when it comes back.
                • guitar9199
                  • Sep 2016
                  • 1100
                  Perhaps is considered "Normal" where you are, but in most other countries it's considered fraud or misrepresentation. A used/reconditioned machine can be sold as used...but to roll back the main counter in order to sell the unit as "new" can get you into all sorts of legal trouble! I'm not sure what sort of Consumer Protection Laws you have in your country, but here in the US they're quite specific about not doing this sort of thing.
                  We sell reconditioned machines all the time.... We tell the customer that even though the machine has "XXX" amount of copies on it, all the consumables inside the machine have been replaced so we can "Warranty it" as if it were new. This saves them a lot of money (Usually about half of retail for a brand new unit), and gets an even OLDER machine out of the field.
                    MAYBE IN YOUR COUNTRY....not in.the USA!
                      throwing the BULLSHIT card..
                      all you have to do is print out the METER page before you deliver it ... print another when rental is done subtract 2nd from 1st...
                      POOF total reading for the rental time.
                      • Caffeine
                        • 391
                        There is nothing normal about it.
                        If you're renting it out, the customer doesn't care what the meter is. So track their meter in an legit way, as others here have described.
                        But don't try to tell those of us here that rolling back the main meter is NORMAL.
                        • martinsadlak
                          • Jun 2019
                          • 2
                          reset not...newer, becouse printer has 3 EPROM. pull another EEPROM from another machine and copy it... or start procedure new machine. Not xerox technical only XEROX engineer
                          • Sandy Marino
                            • Dec 2021
                            • 18
                            yep, jack it up on blocks and put in in reverse til it runs out of toner
