Xerox V80 IBT Assembly
  • mmpmoore
    • Jun 2025
    Good day all,
    I have an error code 042-326 on my V80 which I see is related to the IBT belt. I have a second machine that I want to pull the IBT Belt and swap to the main machine. But I cannot figure out how to get to the IBT assembly. Any assistance is appreciated.
    Jim
    Re: Xerox V80 IBT Assembly
    Originally posted by mmpmoore
    Good day all, I have an error code 042-326 on my V80 which I see is related to the IBT belt. I have a second machine that I want to pull the IBT Belt and swap to the main machine. But I cannot figure out how to get to the IBT assembly. Any assistance is appreciated.
    Thanks Jim
    clearly you:
    A) aren't a tech
    b) don't own a service manual
    • chubblies
      • Jun 2011
      • 154
      Remove the IBT cleaner box, pull out the marking tray to its service position by pressing tabs on the rails, unscrew the IBT and it will pull out on rails, then lift it out of the rails.
      Sounds like you do not know what you are doing though, so I would not attempt this unless you are competent to do so as you could cause lots of expensive damage
      • mmpmoore
        Thanks. Appreciate it. Just trying to get up and running while waiting for service. I have removed the IBTcleaner and pulled out the tray. Just wasnt clear on which screws to remove for the IBT assembly itself.
