xerox PWS gsn lock
  • NEOTECH
    • Dec 2010
    • 69
    [Misc] xerox PWS gsn lock
    hi every one i need to know about non xerox 12 pws gsn lock for windows 10 i am new user i install PWS GSN Clint lock installation is fully complet when i open
    internet explore PWS home page appear but also asking add new user and password how can i add new user and password.
    or/and no need to add user and password how can i use this plz if any one have idea help me i am first time using this non xerox pws gsn lock.
    i see the all previous post related to this but i cannot find the solution.
    thanks.
  • Slr1717
    • Feb 2019
    • 6
    Re: xerox PWS gsn lock
    thanks.
    Its unbbdhdhdudjddu
    • rockdude
      • Feb 2011
      • 257
      Xerox higher end machines are not really suited to newbies.
      This is no reflection on your mechanical abilities.
      Intellectual property as close to the vest as they can.
      Xerox machines beyond the basic models have their manuals installed on laptop
      computers and are called edocs (Electronic Documentation) these higher end machines
      are not available in a pdf format.
      The GSN Lock must be activated before you can view and search the EDOCS.
      You are asking how to circumvent the GSN Lock which requires a User Name and Password.
      This username and password is verified through the internet at Xerox.
      Even if someone gave you their user name and password, it has to be changed and re-verified every 60 days.
      There were some hacks to the earlier PWS systems and GSN Locks.
      I know of none to the latest PWS and GSN versions.
      • pimpdadykool
        you can use the old crack method just set your computer date to before January 31 2018 just did it today and it work on window 7 64bit release 11.6
        will try it for window 10 on a test PC
        • Sujay
          • 2
          thanks.
          Hey my name is sujay Mondal. I'm from India. By profession I'm a service engineer of Xerox machine.
          I will give you full solution on this. But I want to know and confirm something...
          1) which operating system you used?: may be windows 10 right?
          2) do you have gsn pws 12 software? ( I will crack it)
          3) do you have teamviewer remote desktop software? ( I'm trying to install on your pc)
          If you you have gsn pws 12 software then zip it and send me on my email address or share with on Google drive. I will crack gsn pws 12 software and resent you. Then teamviewer thorugh install your computer.
          My email address is (aditya9231@gmail.com )
          Thank you
