Scan to email Xerox Workcentre pro 123
  • wmoussa
    • Feb 2019
    • 38
    Hey all,
    Appreciate any help, I have been struggling with this for a week now, I am trying to configure scan to email on a Xeroc Workcentre pro 123, when I hit the scan the printer goes "sending" for 20 seconds, then gives me error code 016-761.
    I am trying to configure a gmail account , I tried playing with the parameters a lot, changing here and there, there seem to be something missing
  • rockdude
    • Feb 2011
    • 257
    Re: Scan to email Xerox Workcentre pro 123
    Did you set the gmail account to accept less secure apps?
    What ports did you use for gmail?
    More info please.
      Originally posted by wmoussa
      Hey all, Appreciate any help, I have been struggling with this for a week now, I am trying to configure scan to email on a Xeroc Workcentre pro 123, when I hit the scan the printer goes "sending" for 20 seconds, then gives me error code 016-761.
      clearly didn't do a google search!
      besides you gave us NO info OTHER than the error code..
      no tried settings for the gmail setup...
      no info on server settings nor EXACTLY how the WCP123 is setup.
      • wmoussa
        • Feb 2019
        • 38
        so here are all the settings on the images attached
        • wmoussa
          • Feb 2019
          • 38
          [ATTACH=CONFIG]42664[/ATTACH]
          and here is the http settings
          the gateway address is the intent modem/router address
          • wmoussa
            • Feb 2019
            • 38
            and here are the rest of all settings
            • rockdude
              • Feb 2011
              • 257
              You must have better eyes than me cause I can't read any of the settings from the pictures you posted.
              Please find a better (and clearer) way to post settings.
                Maybe PDF?
                • wmoussa
                  • Feb 2019
                  • 38
                  Maybe PDF?
                  here how about this, tried my best and sorry for the previous.
                  I also tried these ports, as per gmail, I feel its something with authentication -
                  Step 2: Change SMTP & other settings in your email client
                  Use the table below to update your client with the correct information. For help updating your settings, search your email client's Help Center for instructions on setting up IMAP.
                  Incoming Mail (IMAP) Server imap.gmail.com
                  Requires SSL: Yes
                  Port: 993
                  Outgoing Mail (SMTP) Server smtp.gmail.com
                  Requires SSL: Yes
                  Requires TLS: Yes (if available)
                  Requires Authentication: Yes
                  Port for SSL: 465
                  Port for TLS/STARTTLS: 587
                  Full Name or Display Name Your name
                  Account Name, User name, or Email address Your full email address
                  Password Your Gmail password
                    • 30195
                    Requires SSL: Yes
                    Port: 993
                    Requires SSL: Yes
                    Port for SSL: 465
                    authentication ON use full gmail address also password
                    Sender must be the same
                    does you machine support tls or ssl or both? set correct port
                    set one dns to 8.8.8.8
                    less secure apps ON
                    pop3 information delete not needed
                    • wmoussa
                      • Feb 2019
                      • 38
                      More info please.
                      Yes I did set the gmail to accept less secure apps.
                      and I tried these ports, as on gmail guide
                      Less secure app access
                      Your account is vulnerable because you allow apps and devices that use less secure sign-in technology to access your account
                      On
                      Turn off access (recommended)
                      Requires SSL: Yes
                      Port: 993
                      Requires SSL: Yes
                      Port for SSL: 465
                        • 30195
                        On
                        Requires SSL: Yes
                        Port: 993
                        Requires SSL: Yes
                        Port for SSL: 465
                        ssl on port 465?
                        • wmoussa
                          • Feb 2019
                          • 38
                          less secure apps ON
                          authentication ON use full gmail address also password , Yes did that
                          Sender must be the same , sorry what do you mean, its the same full address and password everywhere it requires email and password
                          does you machine support tls or ssl or both? set correct port , it does not show tls nor ssl anywhere on the printer setting, it shows on APOP authentication, pls see attached 1 page PDF
                          set one dns to 8.8.8.8 , yes I did that
                          less secure apps ON , yes I did that
                          pop3 information delete not needed[, yes did that
                          **** still not working
                            • 30195
                            don't see ssl setting
                            If NO ssl or tls setting you can
                            try no auth will only send to gmail accounts
                            aspmx.l.google.com
                            Port 25
                            TLS not required
                            Dynamic IPs allowed
                            Mail can only be sent to Gmail or G Suite users.
                            Configuration options
                            • Options: Port 25, 465, or 587
                            • Secure Socket Layer (SSL)/Transport Layer Security (TLS) protocols.
                            • Dynamic IPs are allowed, but a static IP might be required due to authentication requirements.
                            • Port 465 (SSLrequired)
                            • Port 587 (TLS required)
                            • Dynamic IPs allowed
                            • Port 25
                            • TLS not required
                            • Mail can only be sent to Gmail or G Suite users.
                            • wmoussa
                              • Feb 2019
                              • 38
                              aspmx.l.google.com
                              Port 25
                              TLS not required
                              Dynamic IPs allowed
                              • Port 25
                              • TLS not required
                              it does not show tls nor ssl anywhere on the printer setting, it shows on APOP authentication only, so I am guessing it has no SSL nor TLS,
                              Any email service provider that can accommodate that, other than gmail ?
