Xerox 700 error code 041-326
  • Kwaku01
    • Aug 2018
    • 121
    Hi,
    I'm getting error code 041-326 on my xerox 700. Your help would greatly be appreciated!
    Thanks in advance!
    J
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox 700 error code 041-326
    Blown fuse on the power supply. Rear bottom left
    • Kwaku01
      • Aug 2018
      • 121
      Thanks! I've placed an order for fuse:
      Xerox DC 700 PWBA-PHD 960k28872
      • Kwaku01
        • Aug 2018
        • 121
        We've replaced the blown F3 fuse and replaced the PRE_REGI_MOT thinking that was the
        cause but the f3 fuse blew up again. We don't know what to do now. The last option is to replace the MCU PWB board but before
        we do that, we want to find out if anyone with similar issue managed to fix the problem and how they did it.
        J
        • Milo Wilson
          • 499
          Check wiring from pre-reg motor to that board to see if anything is pinched or shorting to the frame.
          • kado
            • Apr 2019
            • 18
            J
            I am sure you lost your +24volt on LVPS...check the supply come from with AVO meter and fix it. iam fammiliar with this model.
            pls reach me on Whatsapp +62 813 3333 8918
            Regards
            • Kwaku01
              • Aug 2018
              • 121
              Regards
              Thanks mate! We've lost +24volt on LVPS. However, we've bridged 24 power supply from elsewhere. Anyway, will try and reach you on whatsapp. Cheers!
