Streaks on black only
  • Alastair38
    • Apr 2019
    • 24
    I have an issue with streaking on black only, the color blocks print fine. I've changed the drum and it's not that, I figure it can't be the transfer belt or the fuser, as colors are fine, I've put in a new genuine Xerox black toner, the developer is not overdue, and the 2nd btr looks fine, I gave it a clean. Anyone got an idea for the most likely culprit? It's a Fuji Xerox SC2020.
    Re: Streaks on black only
    [ATTACH=CONFIG]42656[/ATTACH]
    You changed the drum... oem new?
    did you clean the laser glass?
    if yes...
    my bet on dev unit
    • Alastair38
      • Apr 2019
      • 24
      if yes...
      my bet on dev unit
      ok thanks, I'll look at that tomorrow.
