Xerox 700 error code 041-344
  • Kwaku01
    • Aug 2018
    • 121
    Any suggestion would be appreciated greatly!!! We've been having error code after error codes on our Xerox 700. The new one is 041-344. After a search online for help,
    it came accross that IOT F1 is blown.
    I spoke with Xerox and they send me a picture of where the correct fuse is but I can't locate it at the rear of the printer...please see attached.
    J
  • Kwaku01
    • Aug 2018
    • 121
    Re: Xerox 700 error code 041-344
    Hi, please is anyone able to assist with below error code "041-344" post...xerox sent me below options to look at. I've tested the F1 Fuse and it's ok. I've tried almost all options and now I'm trying to locate the decurler/Decurler Inverter Drive motor to find the part 127k51900 to test it but can't seem to find it. I'm not sure what to do now, Please any suggestions?
    • Kwaku01
      • Aug 2018
      • 121
      Now the error code switched from 041-344 to 041-345...
      • xcopytech
        • Aug 2006
        • 1794
        Front door interlock.
        • Kwaku01
          • Aug 2018
          • 121
          Hi, Thanks for your response.
          We've:
          - Checked resistance value between terminals of IOT Exit Motor as recommended, approximately 3.2 ohms
          - Checked resistance value between terminals of Invert In Motor as recommended, approximately 3.6 ohms
          - Checked the power supply to the IOT Board, 24V
          - Checked the Fuses, its ok
          - Swapped door Interlocks, error remains
          - Replaced IOT board, error remains
          We left the front door open and turned on the printer. The printer turns on with a message and icon 'close door screen', when exit
          from the close door screen, the home screen appears with COPY, NETWORK, SCAN. However, the printer wouldn't print.
          We then closed the front door and an error message appeared, "Fault/error a fault has
          occured switch off the machine.
          ensure that the
          screendesappears before swithing it on 041-344"
          Please any other suggestions we're out of ideas?
          • Kwaku01
            • Aug 2018
            • 121
            I double checked the IOTD at P437 and the voltage reading was 1.56v instead of 24v. What could be the cause and how do I fix it? Please help anyone!
            • InterfaceP
              • Jun 2013
              • 488
              Sounds like the LVPS.
              • Kwaku01
                • Aug 2018
                • 121
                Thanks for your feedback. I took out the LVPS and plugged it on a different power point and got 240V AC input but the output measured zero volts between P/J514-8 and P/J514-7 which is meant to be 24V DC. Please, could this mean that the Main LVPS is gone? Or, do I have to put the main LVPS back on the machine and test it to get the right DC output Voltage reading?
                J
                • InterfaceP
                  • Jun 2013
                  • 488
                  Yes, replace it they frequently go bad.
                  • Kwaku01
                    • Aug 2018
                    • 121
                    Finally, I found the cause of the error 041-344, 041-345, LVPS MAIN!!! The 24V power supply to the IOTD board was bridged and the error code went and after the machine was on for about 30sec a new error code came on, 0412-313. Which I think also point to the same cause, LVPS MAIN.
                    Please, do you know anywhere I can get a secondhand part?
                    Xerox 700 AC Power Supply
                    105E17901
                    Thanks for your help!
                    Jeff
                    • Kwaku01
                      • Aug 2018
                      • 121
                      Hi,
                      I found out the error code for 041-344, 345 was the LVPS. After bridging the 24V supply to the IOT Board, the error code was gone and I was able to print. However, the very first error code I had before the 041-344, 345 has come back (041-326). The error code 041-326 came back again whilst printing. I had located the fuse 3 and found it blown on PWBA-PHD 960k28872 and replaced it, as adviced earlier by a technician. This time, I've checked the fuse 3 and all the fuses on the PWBA-PHD 960k28872 and they all seem to be ok. Please any advise? What could be the cause for the error code 041-326 and how would I rectify it?
                      Thanks for your advise
                      J
