Xerox Docucolor242 passwords reset
  • wichwetyl
    Hello guys, I need to reset passwords on the Xerox Docucolor242, how can I do that and which are the default passwords?
    Thank you
  • wichwetyl
    Ok I found it myself, just press 0 for 5 sec and then simultaneously the green button. Insert code 6789 and then push the ok. Then the key button and you're into the admin section where you can change admin and passw.
    • ck1
      • 485
      thanks for your sharing .
