Xerox 700 error cide 041-370
  • mshabban
    • Jan 2017
    • 101
    Hey guys ,just wondering if anyway has cone acrose thia code before,am really sta
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox 700 error cide 041-370
    Code doesn't exist for 700, but on a 560/C60 line it refers to the Tray Module PWB Fuse 3 fail.
    • mshabban
      • Jan 2017
      • 101
      Re: Xerox 700 error code 045-315
      Thanks mate , just got confused as am having two machines down with faulty code , sorry ,the press 700 is having error code 045-315, was workingg ok until removed changed the black drum corotron Assy ,but now just gives me the code at warm up , really messed up here , i changed the ROS Cables prior when it brought the same code a month ago , but now i wonder what brings it up now.
      • InterfaceP
        • Jun 2013
        • 488
        Yea, those flat cables are a pain in the arse. Change NVM 749-079 = 0.
        This wont fix the problem but will make the error code go away. If you ever do a NVM reset you will need to set it again.
        Cheers!
