jamming with error code 077-115
  • Reeves
    • Apr 2012
    • 277
    [Jamming] jamming with error code 077-115
    Hi i have a xerox 700 jamming just half way from the machine into the finisher with error 077-115
    when photocoping the copy is coming out okey but when i command a print job it ll jam half way into the finisher what could be the problem
    • 22808
    Re: jamming with error code 077-115
    why start another thread for the same topic?
    • InterfaceP
      • Jun 2013
      • 489
      This is associated with the CIS, its located under the metal bracket on the pre-registration assembly, just before the 2nd BTR. Remove the bracket and make sure the connector is secure and not broken. Also preform the CIS set-up cycle in Diagnostics > MAX SET-UP and see if it gives you an "OK" or a "NG".
      • Reeves
        • Apr 2012
        • 277
        am gettintg error 089-642 NG
        • Reeves
          • Apr 2012
          • 277
          now what could be the problem printing 2 to 2 is okey but one sided is jamming both face up and face down
          • InterfaceP
            • Jun 2013
            • 489
            Assuming you did the procedure correctly, I would replace the CIS.
