docucolor 240 calibration with colorcal
  • almerico
    • Oct 2012
    • 58
    [Misc] docucolor 240 calibration with colorcal
    good morning, when I go to calibrate the scanner of my docucolor 240 with colorcal I get the kodak gray scale error not detected. The procedure is ok. How can I solve the problem? thank you.
  • InterfaceP
    • Jun 2013
    • 488
    Re: docucolor 240 calibration with colorcal
    Review the procedure and try it again. Sounds like a user error.
    • Tecnico_Xerox
      • Jan 2019
      • 54
      Hello
      in some occasions the dirt that the scanner has generates a bad reading of the test pattern, the advice is that you clean the lamp, the mirrors and verify that the reference of the white color that is in the exposure glass is not stained or damaged.
