phaser 3635mfp-- communication error
  • tuey
    • Apr 2014
    • 120
    have one of these that decided to throw a "communications error- reboot and try again" today. checked manual and found nothing, checked on-line and found nothing for this model. will try fixes that i found for general xerox errors- battery, reseat connectors etc. anyone have this error that can point me in general direction?? thanks- tuey
  • rockdude
    • Feb 2011
    • 257
    Re: phaser 3635mfp-- communication error
    What firmware version?
    • tuey
      • Apr 2014
      • 120
      don't know , can't print it out, do you know of an upgrade that addressed that issue? i'm gonna check the bypass connectors, operator mentioned that the bypass didn't work before the error message and i've read about that issue (bypass connectors) causing that error. it's a weird one. thanks--tuey
      • rockdude
        • Feb 2011
        • 257
        I recently had a machine with the "latest" firmware update.
        Only to find out that firmware version would not allow me to scan to Windows 10 1830 machines.
        Backed up one version earlier and everything worked fine again.
        I would recommend a Altboot to see if that gets you going.
        Also for testing purposes you can try removing the HDD and then try booting. (A bad HDD can sometimes cause your kind of problem)
          have you:
          PD...
          removed any cable BUT power
          PU
          you might be able to boot into SM..
          if not ALTBOOT
            +1
            • tuey
              • Apr 2014
              • 120
              tried a few things this morning, disconnect hd, fax board, checked all plugs on main, tried a different touch screen etc. but it goes to error screen giving me no access to sm or diagnostics, screen will not react. one of the things i noticed today is the error screen sometimes has a header saying communications error sometimes not, some times the header "comm error" appears after being there for a few minutes. i have parts machines so maybe later i'll try different main board etc. and see if i can find problem through process of elimination. thanks--tuey
              • tuey
                • Apr 2014
                • 120
                switched out the main board and all is working. still don't know what caused error but i do know that changing board fixed it. tuey
