Xerox C570 - Error 093-317
  • ATPAS
    • Aug 2019
    • 19
    As in title, we have a problem with a Xerox C570 with error 093-317. We have changed toner, changed drum, changed toner motor.
    Only thing not changed is the toner dispenser. The toner dispenser is the black long thing that all toner motors are mounted to?
    Visible here: YouTube
    We have a C560 spare machine. Is it possible to use the dispenser from that?
  • ATPAS
    • Aug 2019
    • 19
    Re: Xerox C570 - Error 093-317
    Changed the toner dispenser; no luck.
    • adriansto
      • 2383
      Remove black developer housing and inspect the gears.
      • xcopytech
        • Aug 2006
        • 1792
        Did you ever reset code in NVM
        • ATPAS
          • Aug 2019
          • 19
          Problem solved.
          It was the MVN number 762-371 that had the error 3.
          The normal 762-315 was 0.
          • Caffeine
            • 389
            Problem solved.
            If the original issue which caused 752-315 to bump up to 3 was not resolved, it will come back. However, with everything you replaced, you probably got it.
            • alibear57
              • 14
              Problem solved.
              Thanks a million for that information. That error (093-317) appeared immediately after I had replaced the black dev unit from my 242 into my 550. I only intended for it to be a temporary solution until I find the time to refill the other one. This error was doing my head in, I thought I had put the dev unit in the wrong way, or something, and had it out and in about 6 times, before I read your post. Thanks again, I've written it down for future reference (although, I seem to always forget that I've written things down ;-D )
