Service mode on xerox workcentre 5632
  • Juanki
    • Feb 2019
    • 7
    [Error Code] Service mode on xerox workcentre 5632
    Hi guys,
    I'm new in the forum,
    I speak from Spain, Seville
    Let's see if you can help me, I need to go into service mode on a xerox workcentre 5632, the error changed ozone filter change, I put you in situation,
    I have bought this equipment used and in good condition, the fuser life is 98% but the message to change the ozone filter has been skipped and the fuser is correct as I could erase the ozone filter PM so that I can print and copy again ?
    Thank you very much in advance, greetings!
    • 30203
    Re: Service mode on xerox workcentre 5632
    • Juanki
      • Feb 2019
      • 7
      Hello, before making the post I had already seen this video, the problem is that I do not need to change the fuser, life is 98% it seems that the one who placed it at the time did not change the filter and now to reset the problem I have I need to enter the service menu to reset the filter alone! Thank you!
      • Enzo
        • Jul 2009
        • 413
        Hello. Press the 3 side display button and go to the "active messages" section. Click on the filter error and confirm the replacement
        • Juanki
          • Feb 2019
          • 7
          OK, on ​​Monday when I visit the client I will try, thank you very much!
          Enviado desde mi Redmi Note 4 mediante Tapatalk
          • Juanki
            • Feb 2019
            • 7
            Good afternoon, as you explained I carried out the process yesterday and it has been totally effective, the message has been removed and the equipment is in operation! Thank you very much for your contribution, if you ever need anything from Ricoh or Konica Minolta I am a specialist in these brands, greetings!
            • Juanki
              • Feb 2019
              • 7
              Good morning, visit the client on Monday and perform the process and it worked perfectly, thank you very much problem solved !!!!!!
