Xerox 6600V/DNM metered to sold without code?
  • macshag
    • Oct 2019
    • 6
    Good afternoon.
    I've been an owner of a Xerox Phaser 6600 V/N for quite a while. Sadly it can only print one sided.
    Now I have found and bought a brand new Phaser 6600V/DNM on the web from a private seller. This is a Duplex version of that same Phaser.
    Since it has never been used I'm now stuck on the first boot.
    Printer is asking for the 4 digit activation code.
    I don't have a service plan contract so I don't have a code. It is not my intention to use METERED toners since I have 2 sets of brand new SOLD toner cartridges from my first printer.
    If I replace the toner in the METERED machine with the SOLD toner, will it automatically switch to a non-metered machine?
    Do I still need that code after installing the SOLD cartridges?
    Thanks in advance.
  • jonbonse
    • Jun 2009
    • 713
    Re: Xerox 6600V/DNM metered to sold without code?
    Originally posted by macshag
    Good afternoon.
    Thanks in advance.
    How did you get on with this?
      • 22808
      Good afternoon.
      If I replace the toner in the METERED machine with the SOLD toner, will it automatically switch to a non-metered machine? Do I still need that code after installing the SOLD cartridges? Thanks in advance.
      no magical auto update
      contact xerox HQ you have to provide them with exact model and serial #..
      they will generate a code key to switch it.
      • jonbonse
        • Jun 2009
        • 713
        Do you need to be Xerox dealer to do this?
          • 22808
          a dealer might be able.. i know going thru HQ you can get it quick and the correct one.
          • macshag
            • Oct 2019
            • 6
            I haven't contacted Xerox HQ yet, but will try next week.
            I was told that it could only be switched from DNM (metered) to DN (sold) using a snippet.
            But maybe I'm badly informed.
            • macshag
              • Oct 2019
              • 6
              Well I did get is solved. A local reseler provided me with the 4 digit code. I don't know how he got it.
              I entered the code. Printer warmed up. Removed the metered cartridges en installed sold cartridges.
              Printer accepted them.
              Of course I won't be able to use metered toners anymore, but I already figured that one out in advance.
