V180 - 42-384
  • MHeon71
    • Oct 2008
    • 485
    V180 - 42-384
    42-384 is a constant. It will through the code when the copier comes to ready.
    I have replaced the IBT unit, MCU PWB, LVPS1, PH PWB, fly wheel, and 2nd BTR. Has anyone had this issue? I checked on the bulletins I could find.
    Thanks for any help.
    Mark
  • adriansto
    • 2329
    Re: V180 - 42-384
    Check AC PSU (PL18.5 item #2).
    • MHeon71
      • Oct 2008
      • 485
      Re: V180 - 42-384
      Oops, the AC PSU is one of the parts I replaced, I forgot to type it in. Thanks
      • MHeon71
        • Oct 2008
        • 485
        Re: V180 - 42-384
        The 42-384 was a stupid solve. I was receiving different 42 errors and I swapped out the IBT unit. The new IBT unit did not have the encoder sensors to the right of the IBT motor like the original one had, causing the error. I put the original IBT belt back in and it solved the 42-384 code. I eventually solved the other codes as well.
        The IBT unit with no encoders works fine in the machine I took it from. It looks like it had a manufacture date of 5/19 and do not know the reasoning to it yet.
