Xerox 700 digital color press
  • pbblueprint
    • Oct 2019
    • 2
    [Jamming] Xerox 700 digital color press
    Hey.. I am new to this and praying that I can get some assistance... I have a xerox 700 DCP and it is jamming in areas 1 and 2? prior to the jamming occurring, the guy that cuts my cardstock said that my registration was off.. help please.. been down for 2 weeks and a small business and need this machine.. thanks for anything
    bobbie jo
    Re: Xerox 700 digital color press
    Originally posted by pbblueprint
    Hey.. I am new to this and praying that I can get some assistance... I have a xerox 700 DCP and it is jamming in areas 1 and 2? prior to the jamming occurring, the guy that cuts my cardstock said that my registration was off.. help please.. been down for 2 weeks and a small business and need this machine.. thanks for anything bobbie jo
    sounds like you need a certified tech out.. you need parts replaced
    how many pages on machine?
    PM's done on time?
    are you sure the paper trays are set to the right size - type - weight?
    what have you done to fix it?
    • pbblueprint
      • Oct 2019
      • 2
      Hey Phil...the machine was purchased out of warranty so all work has been done by myself. It currently has 1,761,386 pages on it.. I have recently replaced the registration drive motor gear and its still jamming.. However.. I just tried card stock to see if there was any change.. Previously I was running plain bond out of all trays and yes, all settings are correct on that end. It will run card stock only in tray 6. I apologize if I am not using the correct terminology.. thanks
        i do believe that you need to run: cardstock, heavy , labels from the MPT (fold down on side)
        did you check your owners manual for the gsm - type for paper specs?
        sometimes (when newer) it will work from other trays but it is not recommended due to thickness making turns in paper path
        • Milo Wilson
          • 502
          You can give me a call. I live in Roger,AR and am an independent xerox service tech. 714-292-6912
          • JulianMue
            • Feb 2018
            • 10
            bobbie jo
            Did you solve the error? I have the same problem at the moment
