Help with Xerox 5855
  • eng_usama
    • 115
    dear friends
    This machine always need alignment and I do iot on service mode
    And never correct the alignment hope if there is a solution anyone can help me with it
    Many thanks in advance
  • howling
    • Feb 2019
    • 35
    Re: Help with Xerox 5855
    have you done the pre requisites before executing the iot alignment.
    make sure first that there is no parts that needs replacement before adjusting otherwise you will get nowhere
    • eunuch39
      • Aug 2014
      • 40
      i would try the registration clutch its KNOWN to slip
      • ahmedfathi
        • Nov 2020
        • 2
        Xerox 5855 service plan
        automatic code generation
        ahmed_fathi3@hotmail.com
          • 22808
          this doesn't have anything to do with this problem.
          • ahmedfathi
            • Nov 2020
            • 2
            I have a problem with Xerox 5855. service plan
            I need to
