Nonxrx toner installed xerox phaser 7800
  • toadman
    • Nov 2019
    • 7
    [Error Code] Nonxrx toner installed xerox phaser 7800
    hi there
    has anyone seen the error "NONXRX TONER INSTALLED"
    with the xerox phaser 7800 ?
    using compatible toner cartridges.
    Re: Nonxrx toner installed xerox phaser 7800
    Originally posted by toadman
    hi there
    you have just answered your question there is not the proper chip installed on toner cart.
    In your other thread "Print defect" I clearly stated the problem was the generic toner.
    there is no need to start multiple threads on the same unit
    • craigster
      • Apr 2016
      • 201
      I had a professor from a university drill hole in his cartridge to refill cheap toner!! what a hack or a fruitlupe snowflake!!!
      • howling
        • Feb 2019
        • 35
        there is no such thing as compatible toner in both xerox or fuji xerox period.( in any brand for that matter)
        it is either original or fake. if using the original you will encounter some cq issues, what more would you expect if you use non genuine
          here in the states and on the internet they ARE referred to as COMPATIBLE.
