ColorQube 9303 pre-heater rolling pump
  • kurbads
    • May 2017
    • 26
    Hi, as suggested in another thread, I ordered a pre-heater for my ColorQube as it had the 089-520 error. Unfortunately the replacement part which arrived has a missing rolling pump.
    Could anybody suggest anything about moving the pump over to the new part.
    Also the reason why I was suggested to get a new part was because it supposedly had sensor cap debonded which does not seem to be the case.
    Maybe if it is not the cap, it is something else? What could it be? Can I assemble one working part from two non-working parts?
    Please anybody with any remote ideas chip in.
    Thank you in advance!
  • prismtech
    • May 2014
    • 199
    Re: ColorQube 9303 pre-heater rolling pump
    [ATTACH=CONFIG]44231[/ATTACH]
    The rolling pump was deleted in later pre-heater models! Plug the new pre heater assembly in and away you go!
    If you look closely you will see the newer unit has a series of springs to pressure the plates. Much improved.
    This has lead to funny service calls where the tech has assumed someone stole a part out of the machine! I have seen people get quite upset after being accused of losing it! lol.
    Sent from my SM-T530NU using Tapatalk
    • prismtech
      • May 2014
      • 199
      As for it not being the cap... it could be any of the associated gear train. Exactly why the piece is spared as a whole and not as individual plastic pieces. It could also be a weak pre heater motor.
      • kurbads
        • May 2017
        • 26
        Thank you. There is another problem. The only time I was able to run the HDD upgrade on an empty drive was when I did it on a blank SSD.
        The upgrade with blank HDD does not work. Nor on a blank SSD anymore for that matter. I have cloned the SSD contents on HDD but it behaved exactly the same so I deleted the HDD contents and tried the upgrade again on blank drive but it does not happen. The upgrade on a HDD with non-operatinal system also does not work.
        Besides the upgrade which went along has some account management and asks me to contact Xerox with serial number of the printer to obtain a validation code to remove a 5000 page restriction which after several unsuccessful restarts reduced down to 4000.
        I would like to install fresh version of OS which would not have the printed page management and which would be either 6xxx version or 7xxx version as I noticed that the upgrade to 7xxx does not do any good. The scanner still does not work and also whole printer does not work exactly it did not work with the old 6xxx version and the old pre-heater.
        So my question is how did you put the FW files on the USB stick? What did go into Altboot folder and what else did go where. E.g. did you need Upgrade folder at all? And how do you insert the USB, before you turn on the printer with blank HDD or after? Because it just boots, blinks the USB few times and restarts repeatedly.
        I also tried to remove the network cable to prevent it from looking for upgrade files on FTP server but that also did not help. As when inserting upgrade USB while booted into OS, it would sometime showed message "Creating Altboot", went into restart and did nothing.
        Sorry for so many questions. It is just there is lot on my plate. And I do not know were to start. Especially because I am in UK and will visit Latvia for 4 days at end of January to attempt revive the printer for the last time. If no, it goes to scrap.
        Please could you enumerate my questions (at least the answerable ones) and answer them one at a time?
        • prismtech
          • May 2014
          • 199
          160gb to 250gb sata mechanical drive only. Ssd will cause trouble.
          Fat 32 formatted usb 2.0 stick only. Recommend 8gb. Newer usb 3.0 will fail.
          Create ALTBOOT directory in root of stick. Place downloaded fw contents in folder. Create 0 byte upgrade option file as specified in the other altboot thread in this forum. Power on machine with your new blank hard drive and it will be fine.
          Worry about the page count message once you get up and running.
          Printer will be fine if you follow instructions as listed. You can also ask here when you are there if you run into trouble.
          • kurbads
            • May 2017
            • 26
            I have asked a friends son, a teenager there, who agreed to help. He installed the new heater but he says that it still shows the 089-520 error.
            I will ask him to try and connect the empty 250Gb HDD and try and make a usb flash. The one he uses is a 4Gb one. And it did work the last time.
            I can't put a finger on it what are we doing differently this time.
            How do I worry about page limit later? Is it common for all connect key FW versions? Or are there versions without it? May I take care about it in advance?
            • prismtech
              • May 2014
              • 199
              89-520 is going to show until you clear the error codes in the service mode.
              4gb should be fine. Try others too.
              Until you load new firmware, I cannot help with the other issues. You need firmware and the service mode.
              • zagrex
                • Dec 2011
                • 63
                Hi
                Don't bother too much your problem is registration assembly out of order
                Xerox order code :
                801K37710 Registration/Preheat assembly (complete)
                • kurbads
                  • May 2017
                  • 26
                  Originally posted by zagrex
                  Hi
                  Xerox order code :
                  Thank you for your reply!
                  Is it not the part I just replaced? And how I do not bother? Not bother to fix the printer of not bother that there is a problem?
                  How do I contact Xerox to remove the limit on number of pages I can print after the upgrade?
                  By the way, the boy does not see the error anymore but he says that the HDD I had there seams to be dead. I am urging him to get one somewhere. If he manages, how do you reset error in Service mode? Let alone, how do you enter the service mode? This is the first time I hear the ColorQubes have service modes.
                  Is it this one:
                  Originally posted by Exok
                  You don't need diagnostic software for this machine, it has built in diagnostics.
                  To enter diagnostics mode:
                  Press and hold the # , *, STOP keys.
                  Enter passcode 1991 then Enter.
                  What do I do in it? At what point do I press it?
                  Thank you!
                  • prismtech
                    • May 2014
                    • 199
                    Is it this one:
                    Thank you!
                    You have replaced the part. You do not need to replace the part again.
                    That is correct to enter the service mode.
                    First you need to get replacement hard drive, then come back here and make a report. After that we can address the print limit.
                    • kurbads
                      • May 2017
                      • 26
                      Finally I am back in Riga. For 4 days. They will prove crucial.
                      I brought an empty 160Gb Seagate 2.5" HDD. Copied ColorQube_9301-9303_system-sw#07218000907200#.DLM onto an empty 4gb USB drive into folder ALTBOOT and printer picked the new HDD and USB straight away.
                      All so good but after fresh install, it is where it was. Printer says it is ready to print but shows not enough resources and once the trays are opened and closed, shows 0 resources. The A4 tray paper stack receeds on opening and does not lift up after closing.
                      It displays the scanner fault message and the resaurce plan warning. Also given that waste ink trays are empty, it has not warmed the inks either.
                      I will try the service menu reset now.
                      Update:
                      Fault history in service mode among other things shows 388-522-00 Preheat thermistor failure
                      and
                      399-736-00 ThermistoreMediaPreheatOpen
                      I will shut it down and check the replaced heater unit for any left open anything.
                      Also about scanner it says
                      362-310-00 IISS/Scanner -Controller comunication Fail
                      On exit from Service menu it says Call for assistance quoting 088-502 Error Code
                      Update2
                      I checked the replaced pre-heater and found out that there are only 2 wires out of 4 connected.
                      So I reconnected them and turned the printer on and there is minor improvement.
                      While it still asks for all new settings including if it is on customer site but now after going through wizard it lifts the trays and has started to heat the ink. The room smells molten candlevax.
                      I am not sure if this is good news as this means that it will poor tens of grams of ink into waste on each restart.
                      If it prints now, at least the way it did before, the problems to sort will be
                      - scanner fault
                      - resources plan
                      - settings reset
                      Hey, it just struck me, among error messages there was one about NVM POST something with comment about possibly dead battery.
                      So that much I have figured (whats causing resets). Please help me with the paper plan and scanner fault and where to stick the new battery when I buy it!
                      Update3
                      Hurray, it printed the Head Cleaning pages. I will leave it for tonight and wait for your answers.
                      • kurbads
                        • May 2017
                        • 26
                        Update4
                        The printer works now. It printed the 4000 pages of courtesy period which luckily was reset on printer full restart.
                        It still asks for all intro settings on power on like if it is on customer or distribution site, date and time, units etc.
                        I suspect that is NVM battery. The scanner still does not work.
                        Interestingly before it goes into restart to warm up the inks, it says scan and copy servies available but after restart it complains about the scanner error.
                        • prismtech
                          • May 2014
                          • 199
                          Update4
                          Sounds like the cabling for the scanner to mcu is not connected.
                          Did you load North American firmware on this unit? It sounds you did. That would explain the 4000 sheet message. If it was activated European you need to stay European.
                          • prismtech
                            • May 2014
                            • 199
                            Update4
                            Little Yellow battery is bad.
                            If you loaded north American firmware you are better off just getting a battery + north American nvm chip. Or load European firmware.
