xerox WC 7845 image quality
  • issambass
    • Dec 2019
    • 31
    i have a xerox WC 7845 i have this problem in image quality when i printing2019_02_15 11_01 Office Lens.jpg2019_02_15 11_01 Office Lens 1.jpg
  • Exok
    • Jun 2011
    • 750
    Re: xerox WC 7845 image quality
    Enter diagnostics and print each individual color as a solid test pattern at 50% fill.
      Originally posted by issambass
      i have a xerox WC 7845 i have this problem in image quality when i printing[ATTACH=CONFIG]44433[/ATTACH][ATTACH=CONFIG]44434[/ATTACH]
      you have given us NO info to help other than to dig for more things needed:
      how long since pm's done?
      what are the lifes on the drums/belt/fuser?
      oem or compatible supplies?
      any error codes?
      do you have a SM?
      have you tried to clean it?
      clearly not a tech... ( if you were and you called Xerox tech support you'd get laughed at and hung up on)
      seeing the 'tiger stripes' indicates to me that you have developer issues.
      • gpoffmachs
        techie
        • Feb 2005
        • 55
        is this an internal print or a copy
        Techie
          "i have a xerox WC 7845 i have this problem in image quality when i printing"
          • gpoffmachs
            techie
            • Feb 2005
            • 55
            with this banding it definitely looks like dv
            Techie
            • issambass
              • Dec 2019
              • 31
              this internel xerox printe
              i have changed : the belt/drum /dev.eloper
              • jhalfhide
                • Apr 2015
                • 454
                That's your Dev bias board. Not had it on a workcentre but have had this exact output on a Versant.
                Stop printing as all your Dev will be going out to the waste container and you will need to refill again
                Sent from my LYA-L09 using Tapatalk
