Xerox C60 117-348
  • Bert
    • Aug 2025
    [Error Code] Xerox C60 117-348
  • zagrex
    • Dec 2011
    • 63
    Re: Xerox C60 117-348
    Hi you have problem fix it need install new software
    necessary procedureDownload Software from USB Drive
    1. Copy the software ( .bin) file(s) and any supporting documentation from GSN library 11623 to the PWS.
    2. Insert the USB Drive into the PWS. In the root directory, create a directory labeled dwld.
      NOTE:
      Generally, the All-in-One file is used when upgrading to a newer version of software. If you are reinstalling software at the same version, you must use individual files, as the All-in-One option will not overwrite a file of the same version. When installing individual files the machine software version will display as either all zeroes or as the last file that was downloaded. This is a display issue only. Loading the All-in-One file after loading individual files will correct this.
    3. Copy the appropriate software file(s) from the PWS to the dwld directory on the USB Drive.
    4. Insert the USB Drive into the USB connector on the front panel.
    5. Turn On the power while pressing the Energy Saver button. Hold the Energy SaverDownload ModeTRANSFERRINGProcessing 0/10, 1/10, ....10/10
    • knightfall
      • Jul 2006
      • 633
      the sd card is not a blank card it contains the bios for the copier so if you put a blank one in it will not work.
      Get your facts first, and then you can distort them as much as you please.
      • azehnali
        • Nov 2009
        • 679
        did you fix the problem?
        I have the same issue
