Activation code wc5330
  • electron2001
    • Oct 2011
    • 19
    Hi, I have a new packaged xerox wc 5330 that required an activation code. Can you help me please.
    Re: Activation code wc5330
    call xerox
    • zagrex
      • Dec 2011
      • 63
      1. Press the login button on the Control Panel. This will bring you to the keyboard for admin username and password
      2. Enter admin for the username and 1111 for the password. The user type field (upper right corner of UI) will now be green, and read Admin
      3. Press the Machine Status button on the Control Panel and then press the Tools tab
      4. Select Features, Scroll down and Select Maintenance then Select USB Key
      5. Locate the Dongle (Initialization Kit USB Thumb Drive) in Tray 1 inside the tray in the front right cover
      6. Insert the Dongle in the Front USB Port and Select Start on the Screen
      7. Once the MFP Option is Installed remove the Dongle and store back in Tray 1
      8. Select Reboot on the Screen
      • Hassann
        • Jul 2023
        • 75
        ุง have same problem with it
        Can you tell me how did you fixed it
        Thanks in advance
