Xerox versant 80 error code
  • nstavrin
    • Jan 2020
    • 4
    [Error Code] Xerox versant 80 error code
    Hello
    i have xerox v80 and error code 093-314
    please your help to solve this error
    thanks
  • EAHG
    • Jan 2020
    • 20
    Re: Xerox versant 80 error code
    Dispense Yellow Broken.
    • nstavrin
      • Jan 2020
      • 4
      Hi EAHG,
      we change the Yellow Dispense with a new
      continue the same problem
      maybe need some codes to reset from the machine system?
      • EAHG
        • Jan 2020
        • 20
        Originally posted by nstavrin
        Hi EAHG,
        you change the dispenser? or you change the toner. there are no codes to reset.
        things to check...
        1. dispenser motor
        2. agitator and toner tube (physically,although you said you replaced the dispenser)
        3. and last is turn off the mc pull out the consumables then turn on then one by one install the consumables.
        • nstavrin
          • Jan 2020
          • 4
          things to check...
          1. dispenser motor
          Hello EAHG and thank you for reply
          we turn off the machine and pull out the consumables then we turn on then one by one install the consumables and working perfect.
          thank you very much for your help
          Best Regards
          • EAHG
            • Jan 2020
            • 20
            you're welcome
