Xerox Workcentre 7556 Crazy weird random smudges
  • bjquines
    • Sep 2019
    • 5
    Hi,
    I've been having weird smudges when printing, sometimes it disappears. Most of the time it shows, tech supports couldn't figure out what the problem is so I was hoping to get some answers in this forum. Most of the time it was the Magenta, but as you can see in the other photo, this includes the Yellow and Cyan. Hope to here from you guys, TIA!
    83071271_787255068445465_5720200932742922240_n.jpg83473027_616819002436060_2611707314196971520_n.jpg
    • 22808
    Re: Xerox Workcentre 7556 Crazy weird random smudges
    Originally posted by bjquines
    Hi,
    [ATTACH=CONFIG]44745[/ATTACH][ATTACH=CONFIG]44746[/ATTACH]
    what are the page counts on: ITB ..Drums..Dev units.. fuser?
    are you feeding paper SEF or LEF?
    it could be the ITB ..but I would look closer at drum/devs
    • bjquines
      • Sep 2019
      • 5
      Hi, thank you for the quick response, tech supports already checked that. This unit was overhauled (cleaned). This resolves the issue and printer worked properly again for about a week, then it came back.
      I'm guessing that the toner is leaking somewhere inside the machine?
      I'm using LEF, how can I check the count sir?
        • 22808
        Print counter logs..
        • bjquines
          • Sep 2019
          • 5
          Total Impressions 302916
          Black Impressions 131006
          Black Copied Impressions 31445
          Black Printed Impressions 99051
          Color Impressions 171910
          Color Copied Impressions 8323
          Color Printed Impressions 163316
          Embedded Fax Impressions 486
          Internet Fax Impressions 0
          Server Fax Impressions 0
          Large Impressions 23595
          Black Large Impressions 11135
          Color Large Impressions 12460
          Stored Image Printed Impressions 0
          Black Stored Image Printed Impressions 0
          Color Stored Image Printed Impressions 0
          Black Copied Sheets 29963
          Color Copied Sheets 7897
          Black Printed Sheets 80481
          Color Printed Sheets 123182
          Embedded Fax Sheets 486
          Black Copied 2 Sided Sheets 1164
          Color Copied 2 Sided Sheets 744
          Black Printed 2 Sided Sheets 15515
          Color Printed 2 Sided Sheets 43189
          Embedded Fax 2 Sided Sheets 0
          Black Copied Large Sheets 1275
          Color Copied Large Sheets 2277
          Black Printed Large Sheets 9572
          Color Printed Large Sheets 9679
          Embedded Fax Large Sheets 0
          Embedded Fax Images Sent 964
          Internet Fax Images Sent 0
          E-mail Images Sent 0
          Server Fax Images Sent 0
          Network Scanning Images Sent 33
          Power On Impressions 8
          Is this right?
          • bjquines
            • Sep 2019
            • 5
            • bjquines
              • Sep 2019
              • 5
              This is what the counter shows sir.
              • xeroxsharp
                • Nov 2008
                • 270
                Hi,
                IBT belt cleaner must be changed, not only cleaned. Scan2
                Scan1 - Magenta drum R3 is not ok, try to place it on location R2 or R4, but then the smudges must change colour.
                • Exok
                  • Jun 2011
                  • 750
                  The magenta marks going from front of the machine to the back looks to be a bad drum. The multi color stripes going in the paper path direction look to be a bad transfer belt cleaner.
