Error gray background xerox v7080
  • dacam20590
    • May 2019
    • 30
    hi every
    I am experiencing an error on the fuji xerox v7080 machine (the same xerox 4112)when I printed the paper had the background dotted,paper print no white backgroud .i have replace drum and toner and developer result problem no fix.Have you had such a problem?
    I need help
    I need help
  • xrxdheeraj
    • Sep 2017
    • 23
    Re: Error gray background xerox v7080
    Originally posted by dacam20590
    hi every
    I need help
    I need help
    Have you tried changing complete drum unit or just replaced drum?
    Sent from my Redmi Note 6 Pro using Tapatalk
    • dacam20590
      • May 2019
      • 30
      yes i'm replace drum ,i thing drum error color drum.
      • xcopytech
        • Aug 2006
        • 1783
        Max setup?
        Developer calibration?
        Replace drum unit.
        • dacam20590
          • May 2019
          • 30
          Originally posted by xcopytech
          Max setup?
          Replace drum unit.
          i'm have run maxsetup to toner end,when toner runing update problem no fix.i'm have replace developer and toner and drum result problem no fix.
          Is it possible that the drum will fail?
          drum before color differnt 2 drum color
          • xcopytech
            • Aug 2006
            • 1783
            Corona grid and corona wires?
            What is toner concetration under procon on print?
            Did you calibrated developer sensor?
            • dacam20590
              • May 2019
              • 30
              corona not yet replace, atc measure sensor display normal
