xerox v80 error code 044-383
  • levyk
    • May 2019
    • 12
    [Error Code] xerox v80 error code 044-383
    hi
    having this error code 044-383 and i cant connect to the printer (i cant find this error in the manual) any solution?
    tnx
    levy
  • xcopytech
    • Aug 2006
    • 1748
    Re: xerox v80 error code 044-383
    Fuse F3 on Paper Handling PWB
    • levyk
      • May 2019
      • 12
      tnx
      where do i find it in the manual?
      • Dech
        • Aug 2014
        • 48
        Originally posted by levyk
        tnx
        044-383 PH F3 Fuse Fail [IMG]file:///C:/Edoc/common_e2/images/full_a.gif[/IMG] [IMG]file:///C:/Edoc/common_e2/images/memo.gif[/IMG]
        Bsd-on:CH1.14, CH1.6, CH9.19
        [IMG]file:///C:/Edoc/common_e2/images/description.jpg[/IMG] Fuse3 on the Paper Handling PWB went out.
        [IMG]file:///C:/Edoc/common_e2/images/note.jpg[/IMG]This Fail is the Sub System Fail and when this Fail occurs, +24VDC_C13, +24VDC_Intlk_Delay, +24VDC_Intlk will be cut off. (Refer to BSD CH1.6, CH1.9, CH1.12)
        Procedure
        Turn the Power OFF and remove the Rear Lower Cover. Measure the Resistance Value of F3 on the Paper Handling PWB.
        Is the resistance 5 Ohm or higher?
        Yes No
        Check the connection between LVPS_1 N11A J509_1-2 and Paper Handling PWB J451-5 for open circuit, short circuit, and poor contact.
        Disconnect Connector J450 from the Paper Handling PWB and measure the resistance between the following J450 terminal and GND.
        • J450-B11, B9, B7, B5, B3 (Toner Cartridge Motor Y, M, C, K1, K2)
        Is the resistance 5 Ohm or higher for each?
        Yes No
        Check the following:
        • The connections that are in earth fault (at 5 Ohm or lower) for short circuits.
        • The target components for internal short circuits.
        Replace the Paper Handling PWB. (PL 18.4)
