Magenta background
  • Reeves
    • Apr 2012
    • 296
    [Misc] Magenta background
    I have a dc252 when I print in colour or photocopy its producing a magenta background but if I photocopy or print in black and white copies are Okey I changed DV and drum still producing magenta background what could be the problem
  • xrxdheeraj
    • Sep 2017
    • 23
    Re: Magenta background
    Pls upload 2-3 images
    Sent from my Redmi Note 6 Pro using Tapatalk
      did you follow the SM procedure after changing the DV?
      did you clean the machine b4 replacement?
      did you just replace DV powder?
      or whole unit?
      is there black print visible thru the magenta?
      please upload PDF's of the problem.
      • Reeves
        • Apr 2012
        • 296
        thanks have uploaded the images
        • Reeves
          • Apr 2012
          • 296
          or whole unit?
          The machine was working just fine it just started producing magenta background i suspected the DV so i got a working dv from another machine the problem is still there but the some dv worked just okey in the other machine DV powder i replaced 5 months ago
          • xrxdheeraj
            • Sep 2017
            • 23
            Check for the drum unit if toner in building on drum surface. If yes any of your drum unit could be faulty. Try swapping magenta DV unit with other yellow/cyan and see if same problem.
            Try reseating laser cable and laser unit
            • Reeves
              • Apr 2012
              • 296
              Thanks for the reply i have tried to swap drums still the problem is still there but black and white coping and printing its okey buy coping and printing in color the magenta background is there
              • Reeves
                • Apr 2012
                • 296
                hi i have tried to reseat laser cables and laser unit for magenta and yellow problem still there
                • SeniorTch
                  • Jun 2017
                  • 117
                  seems to be a voltage problem. a charge roller voltage or a Dev housing Bias.
                  105E17680 Charge (Y, M, C) HVPS
                  or
                  604K29270 Developer Bias (Y, M, C) HVPS
                  • xrxdheeraj
                    • Sep 2017
                    • 23
                    Any of 3 dev unit or any of drum units. It's due to voltages. One of your drum unit charging or dev unit is makings this problem due to voltages.
