xerox v80 error code 024-925
  • levyk
    • May 2019
    • 12
    hi all!
    im having this error coming up after every 20-30 copies (not to be exact) although the cyan toner is still full, i have already changed a few new cyan toners, i have already changed the cyan dispenser unit including the motor, and i have already changed the pwb low toner sensor, and its still coming up this error to change cyan toner, anyone can help what the issue can be??
    tnx
    Levy
  • adriansto
    • 2375
    Re: xerox v80 error code 024-925
    Originally posted by levyk
    hi all!
    tnx
    Levy
    Procedure say to check IOt & ESS connectors, cables and if ok to replace first IOT pwb then ESS pwb.
    • Scarecrow
      • Oct 2010
      • 234
      Dev housing.
      • Dech
        • Aug 2014
        • 48
        Does your cyan toner cartridge feed motor run?
        If not, check your F3 on your paper handling (iot) pwb... it could be blown...
