Fault code 033-335 on dcvc5575
  • pengtech
    • 41
    [Error Code] Fault code 033-335 on dcvc5575
    Hi, I am having an error 033-335 on xerox dcvc5575, any ideas to solve this problem. Thank you 🙏
  • elsab
    • Dec 2007
    • 63
    Re: Fault code 033-335 on dcvc5575
    Fax Card issue. You might have to disconnect the fax kit to isolate issue.
    • pengtech
      • 41
      Thanks Elsab, I tried isolate the fax board and clear NVM but still the same problem.
      With no other solution, I tried factory reset and it worked but with data all lost.
