Xerox Apeosport VI C7771 Fault Code 021-414
  • Alex1
    • Oct 2012
    • 285
    Hi all,
    I have Xerox Apeosport VII C7771 with a fault code if 021-414 the machine is trying to connect to the EP. I have checked the following name. The LAN cable connection, The DNS server address settings, The default gateway setting, The subnet mask setting, The EP proxy server URL setting with no luck. Has anyone come across this error and how to get rid of it?
  • shinchan
    • May 2011
    • 195
    Re: Xerox Apeosport VI C7771 Fault Code 021-414
    Originally posted by Alex1
    Hi all,
    hi Alex1.
    I had a same problem with my apeosport v 5070.
    it was a used machine from a company that subscribe to ep-bb program.
    (my theory) when they sold that machine, the ep-bb subscription/account was also canceled by the company. they don't want to be billed again by xerox after getting rid of the machine.
    i tried to clear the ep-bb settings, but it shows error/ timed out.
    the machine is working fine. it can print, copy, scan.
    the downside:
    1. error light indicator will stays on during operation
    2. error history is full with that error 021-414
    3. sometimes customers inform /asks me that error because it's shown on the screen. they thought the machine is not working because of that error.
    so i just told them to ignore that warning.
    if that machine is returned by customer (my lease contract expires). I will try removing the error by copying eeprom of the same make and model (normal condition, no errors) . from there just match the billing information.
    do this on your own risk and remember to make backup on the eeprom before copying eeprom.
    • Alex1
      • Oct 2012
      • 285
      Originally posted by shinchan
      hi Alex1.
      the downside:
      Actually I ended up getting rid of the error. I turned on another machine went into service mode and configured the exact same EP Proxy Server Setup and Proxy Server Settings and went back to normal after the reboot the machines red error light disappeared
      • Eagle
        • Mar 2010
        • 49
        hi Alex1.
        the downside:
        Your correct.
        I fixed that problem but cant remember what i did. Try initialising the IOT
