Xerox 7665 Fiery Hard Drive Cloning
  • Alex5213
    • Dec 2011
    • 26
  • bojans
    • 1313
    Re: Xerox 7665 Fiery Hard Drive Cloning
    As far as I know there is only Network controller for wc 7665, no Fiery.
    If you could find xerox tech, it would be the best solution for you.
    • Alex5213
      • Dec 2011
      • 26
      Is the smart controller sorry (look attached picture), inside this controller is the Hard Drive
      that i need to clone, anyone knows how to do it ?
      • adriansto
        • 2387
        This controller ia part of the machine.
        The WC76xx machine dont work without the controller.
        You can buy machine software and software diagnostic tool to reload the controller software if happen again to broke hdd. You can do that yourself if you have the softwares. For do this you need usb printer cable and ethernet crossover cable.
        • Caffeine
          • 391
          You can't clone the HD from a controller on a 76xx series WorkCentre. They are encrypted with a key and if you put the hard drive from one controller into another (or a clone into another) it won't work.
          The only scenario where it would PROBABLY work is if you were cloning the hard drive of a controller and put it into the SAME controller if the original one failed. As a backup I guess. But it would have to be a block-level copy. And I'm not positive about that because I've not done it.
          You can make clones for Fiery controllers which will work on any same-model controller, but that doesn't work for this Xerox controller.
          • InterfaceP
            • Jun 2013
            • 488
            The Network Controller for the 76xx is a complete pain in the arse. With that said...
            I can only assume that you have two 76xx but only one controller that has software the other does not. The issue with these machines is that the Network controller is the only module that can upgrade the rest. If you try to install a controller on a machine (IOT) that has a higher SW version than the controller you will get a communication fault at start-up. The only choice you have is to have a technician that has the WCCP program to manually install it.
            You could also buy one, given the age of the 76xx you could most likely get one on the cheap. Just make sure it has a software version higher than the IOT you have.
            Best of luck
