C70 Error 117-348
  • dmg93
    • Jul 2019
    • 6
    [Error Code] C70 Error 117-348
    Hello I have a Xerox C70 with the error 117-348 tried loading software but no luck, nor entering diagnostic mode.
    Re: C70 Error 117-348
    [ATTACH=CONFIG]46006[/ATTACH]
    did you try the altboot process?
    • dmg93
      • Jul 2019
      • 6
      Yes but no luck, also tried all this procedures and only the first one worked.
      • jhalfhide
        • Apr 2015
        • 451
        What I'm seeing in the edoc is that the code states you've used an SD card from another machine.
        Sent from my LYA-L09 using Tapatalk
        • dmg93
          • Jul 2019
          • 6
          there is no SD card on the MCU or the processing card, checked also with another module(the one on the side where you plug the ethernet) but same error on both modules no luck
          thank you.
          • jhalfhide
            • Apr 2015
            • 451
            thank you.
            Part 10 shows SD Card
            • jhalfhide
              • Apr 2015
              • 451
              See attached, better quality pic
              • Mubasher
                Hi....
                sorry for stealing your thread. I am having an issue that my C70 is not booting and just lights are blinking in a pattern
