xerox d125 error 016-242
  • mkdirs
    • Oct 2014
    • 177
    system GMT clock fail
    i replace the nvm
    also the pwp
    same error
    any ideas
    Xerotk.com
    xerox copier technician
    Re: xerox d125 error 016-242
    i replace the nvm
    also the pwp
    same error
    any ideas
    replace clock battery
    • mkdirs
      • Oct 2014
      • 177
      the nvm battery ?
      Xerotk.com
      • adriansto
        • 2387
        the nvm battery ?
        Do NOT remove the ESS battery on the D series machines. This will cause and unclearable 016-242 fault code.
        Remove the nvm ess chip from the ess board and remove the battery from the nvm ess chip. This will reset the nvm.
        After reboot, a 124-323 error will appear. Follow that rap.
        • mkdirs
          • Oct 2014
          • 177
          YES I KNOW THAT THE ESS BATTERY WILL destroy the authentication key data on the ess board
          i remove the NVM Battery before and dose not help
          the battery is 3v so its ok
          the machine work perfect but on the screen i have this code
          also i format the hdd and reload software
          slit i have the dame code
          Xerotk.com
          • adriansto
            • 2387
            Another ess nvm pwb, try to sync serial number then complete install wizard.
            • mkdirs
              • Oct 2014
              • 177
              friend the serial is OK am xerox tech so i know what to do when serial not sync
              Xerotk.com
              • Caffeine
                • 391
                It has nothing to do with the serial number being ok. The ESS NVM PWB might be defective, so he suggested replacing it. And if you replace it, obviously you then need to do a fresh sync...
                There is no need to be so aggressively negative when people are just trying to help you. If you don't want suggestions, don't ask. Same as when he was warning you about not removing the ESS battery... How is he supposed to know you already know that? Someone could easily ruin their machine that way so he was trying to make sure you didn't. There's no need to be so snappy back to someone who is just trying to help you, for free.
                adriansto is one of the friendliest and most helpful and most knowledgable people on this site. Don't be rude to him or you'll have me and a lot of other people who greatly appreciate his frequent help to deal with...
                • mkdirs
                  • Oct 2014
                  • 177
                  yes you are right sorry about that
                  i answer like that because if you take nvm battery out the serial will cleared and the machine go up with serial error
                  Thanks for advising me
                  you are right
                  Xerotk.com
                    +1
                    • mkdirs
                      • Oct 2014
                      • 177
                      OK i fix it
                      i change the NVM
                      I use xerox 560 nvm and that work
                      thanks all
                      Xerotk.com
                      • Caffeine
                        • 391
                        OK i fix it
                        i change the NVM
                        thanks all
                        Keep an eye out for unusual "odd" errors over the next couple of weeks... I once did the opposite (used a D-series NVM in a 570) and although I felt like I restored the 570 NVM onto it properly and everything, and it did seem to work for the most part, it wasn't truly compatible. I kept having really unusual errors until I bought a new "blank" 570 style NVM module and installed it.
                        But, it does at least tell you which part was the problem! So even if it doesn't 100% work, you now know that you just need to get a new D-series NVM module.
                        • irdicheku
                          • Aug 2019
                          • 17
                          OK i fix it
                          i change the NVM
                          thanks all
                          May i know what is the nvm. Thanks.
                          Sent from my EML-L29 using Tapatalk
