xerox 6705
  • ahmed abdou
    • Feb 2014
    • 45
    [Error Code] xerox 6705
    hello every one i hqve xerox wide format 6705 when i switch on the machine i have in UI screen xerox 3035 instead xerox 6705
    thanks a lot
    Re: xerox 6705
    thanks a lot
    ok...?
    is this a NEW to you unit? (meaning used)
    does it work?
    any RAP codes?
    does the scan lamp light?
    does it feed paper and make a copy/print?
    what have you done to it?
    are you a trained xerox tech?
    do you have a SM?
    Phil B. " The Dentist "
    • xcopytech
      • Aug 2006
      • 1792
      Re: xerox 6705
      Fuji xerox region xerox docuwide 3035
      Rest of world xerox 6705
      Same machine.
      Set NVM for proper region and country.
      • ahmed abdou
        • Feb 2014
        • 45
        Re: xerox 6705
        i have manual nothing in it i can make copy but not scan and print i can not
