how to solve error 342 322 00
  • blax
    • Mar 2013
    • 78
  • blax
    • Mar 2013
    • 78
    • xcopytech
      • Aug 2006
      • 1794
      Re: how to solve error 342 322 00
      That is error code for cyan drum motor
      Check cyan drum motor from diagnostic mode.
      Replace cyan drum
      • knightfall
        • Jul 2006
        • 633
        If you think its a cyan drum or motor problem switch it with the magenta drum or motor if the fault code changes then its the drum/motor if not its something else.
        It could also be the front door switches change then they have been known to not engage even when the front door is closed cutting off the 24vdc.
        Get your facts first, and then you can distort them as much as you please.
        • blax
          • Mar 2013
          • 78
          thanks to all, i solved, i entered on service mode and failure was Y drum, the cleaning blade was stopping opc rotation, now its solved
