C60 code 093-317
  • apcrap
    • Jun 2010
    • 25
    C60 code 093-317
    Been fighting this problem I just replaced the black dispense assembly and black dv assy with no luck .The machine will run about 100 prints before it codes out .Any suggestions ?
  • xcopytech
    • Aug 2006
    • 1747
    Re: C60 code 093-317
    Check black developer drive clutch
    • irdicheku
      • Aug 2019
      • 17
      Check also dispenser K. Might be blocked
      Sent from my EML-L29 using Tapatalk
      • SeniorTch
        • Jun 2017
        • 116
        check the toner cartridge motor and toner cartridge
        • Zeedras
          • Mar 2015
          • 7
          Check the developer cover that goes to developer tank. Sometimes the plastic on black got fold or broken.
          • Dech
            • Aug 2014
            • 48
            If the toner is blocked, it blows F10 fuse on the iot Pwb and the toner motor sometimes burns its brushes. if this happens replace iot and motor... Check the seal on the inner cover( the toner falls through the inner cover to the dev tank) the seal between the dev tank and inner cover. Ive have factory fitted seals fitted of centre causing the toner to back up in the tube.. You can remove the seal and centre it , or order a new inner cover ( 802K65485 Inner cover assy...) Hope this helps you..
            • ChiChaK
              • May 2017
              • 8
              Can someone write me a NVM code to clean that error on 550 Xerox, seems that design is changed but old post doesnt imported
              Une pharmacie fiable viagrasansordonnancefr.com traitement efficace
              • Dech1
                Senior Engineer
                • Dec 2022
                • 34
