Short on Altalink B8055 "Jam Behind Left Door"
  • rockdude
    • Feb 2011
    • 257
    I have a Altalink B8055 that is showing "Jam Behind Left Side Door". (There is "NO" jam behind door.)
    I used diagnostics to check the seven sensors that can cause this error.
    They all read "Low" (Normal) with the exception of the "Tray 2 tar" sensor.
    I replaced that sensor and it still read "High".
    I then replaced the IOXT PWB.
    After it continued to warm up, and just before it was to print ( I mean right before.) There was a burning smell coming from the machine, and the left door jam error came on the display again.
    I tracked the smell down to a blackened (burnt) component (hard to tell if it was resistor or diode) on the IOXT board.
    Any input is appreciated.
  • Caffeine
    • 389
    Re: Short on Altalink B8055 "Jam Behind Left Door"
    This sounds like one of those "unique to that machine" type of problems that are the trickiest to hunt down... That's a bummer.
    If you suspect that the original IOXT board was fried, and then the new board also got fried after you put it in, and therefore a short as you mentioned, I would trace the wires from that particular sensor carefully from the sensor itself back to where it connects. It could be that there is a pinch in the wire causing it to short to the metal frame where it is pinched (if it is piercing the wire insulation). I have seen those quite a few times cause problems, and they are difficult to track down because they tend to cause very wild problems that sometimes don't make a lot of sense.
    Unfortunately, even if that is what is happening, it COULD be a different unrelated wire that is shorting, it just happens to be representing with the Tray 2 take away roller error.
    Someone else may have a different take, but I don't think the imaging units or fuser are likely causes, unless you had JUST done something with one of them right before it happened the first time? Probably not, or you would have mentioned it, so I don't think they would be high on my suspect list.
    Sorry I can't help more. I'm not strong on the non-Fuji models. But every time I have had an actual short-and-fry, it has been because of pinched wires or wire connectors which had come loose.
    Good luck!
    • rockdude
      • Feb 2011
      • 257
      Good luck!
      Well it looks like I will never know for sure. The customer had me replace all the possible items I thought it might be. I know it had Blown the ITXO PWB, I also replaced the left door assembly complete, and I replaced the fuser, as well as the drum cartridge.
      The machine turned on and is working fine.
      Not sure which component was shorted, but will try supply items in another machine.
      Thanks for input.
      • Caffeine
        • 389
        Thanks for input.
        At least you got it up and running again.
