Xerox Versant 2100 Fault Codes 042-320 and 042-325
  • jasdeep
    • Nov 2020
    • 5
    anyone know the solution to solve this
    also does ayone have edocs for versant 2100?
  • xcopytech
    • Aug 2006
    • 1791
    Re: Xerox Versant 2100 Fault Codes 042-320 and 042-325
    042-320 drum motor Y
    042-325 main motor
    • jasdeep
      • Nov 2020
      • 5
      I put new main motor and yellow motor, still getting same fault codes. It print about 100 sheets and faults out.
      • azehnali
        • Nov 2009
        • 679
        take the fly wheel off the btr and print and see if it gets better
        • xcopytech
          • Aug 2006
          • 1791
          Test motors from diagnostic.
          • Copyrite printing
            • Aug 2023
            • 1
            Hi,
            I have versant 3100 I am getting same errors! could you please let me know did you fix it?
            • Dech1
              Senior Engineer
              • Dec 2022
              • 59
              Check the following:
              • Power supply voltage of the Main Motor (+24VDC, +5VDC).
              • Operation failure of Main Motor (DC330[042-037]).
              • Wear, damage, and gear blockage of the Main Drive Assembly Gear.
              • Operation failure of 2nd BTR Retract Cam Clutch (DC330[094-011/012 (Contact/Retract)] in the Main Motor Assembly.
              • Increased load due to clogging of Xero Waste Toner Collection Auger section.
              If no problem is found, replace the MCU PWB Assembly.
